markj595
Jun 29, 2012Aspirant
How To Fix POWER ISSUE, ReadyNAS Duo V2 RND2000 - MUST READ!
First of all i request this topic be Pinned or sticky set so people can resolve this issue without the pain i have had to endure! - Thanks! If you have this ReadyNAS Duo V2 RND2000 with the radiato...
MisterRico
Aug 28, 2012Aspirant
Hello,
I have a ReadyNAS Duo v2 (RND2000-200EUS) since 07/07/2012 with Radiator Firmware v5.3.5 (this version was installed automatically when I have configured my NAS) and i have the bug of
"the auto power off function" (schedule): IMPOSSIBLE TO RESTART my ReadyNAS after. (I have to remove the battery)
https://www.readynas.com/forum/viewtopic.php?t=64181&p=359905
Normally, this bug has to be solved with version v5.3.4, but after lot of search on internet, I see that lot of people have this bug on version 5.3.5 too.
I have seen a guy on a french forum of Netgear who says: "I have downgraded on version 5.3.4 and reinstalled version 5.3.5 and it is ok now". But I don't want to downgrade my NAS to test.
So conclusion:
Issue is solved if version 5.3.4 was installed before and continue for all new users like me (directly on version 5.3.5).
Please on the next version "5.3.6" (and all versions after) think to correct this bug like you do it on version 5.3.4.
Thank you
Eric
So conclusion:
Thank you
Eric
