markj595
Jun 29, 2012Aspirant
How To Fix POWER ISSUE, ReadyNAS Duo V2 RND2000 - MUST READ!
First of all i request this topic be Pinned or sticky set so people can resolve this issue without the pain i have had to endure! - Thanks! If you have this ReadyNAS Duo V2 RND2000 with the radiato...
tOmki
Oct 19, 2012Aspirant
Yesterday, I have this same problem (power timer- enabled), but with 5.3.6 firmware version.
ReadyNas Duo v2 wont power up (5.3.5)
http://www.readynas.com/forum/viewtopic.php?f=64&t=66095
xcube wrote: Symptoms:
1) After unplugging and replugging the power supply, It would turn on the Power button LED for Half a second and then it would shut down.
2) The fan did not spin
3) The Ethernet Orange LED would blink.
4) The Ethernet Green LED would not blink.
4) Pressing or Holding the power button would not do anything.
5) Holding the Reset button and the pressing the power button would not do anything.
