markj595
Jun 29, 2012Aspirant
How To Fix POWER ISSUE, ReadyNAS Duo V2 RND2000 - MUST READ!
First of all i request this topic be Pinned or sticky set so people can resolve this issue without the pain i have had to endure! - Thanks! If you have this ReadyNAS Duo V2 RND2000 with the radiato...
mattpreston80
Oct 19, 2012Aspirant
Has anyone seen this problem on Raidiator 5.3.6? I did a FW update before doing my first set up and I'm getting a similar problem, if I power off via the browser interface I cant use the button on the front of the NAS until I have disconnected the power and re-connected. Also, WOL doesn't work either until I disconnect power and re-connect. I have checked the bios version, and its Uboot-1_1_4-NetgearDUOV3-V1009 so that should be ok right?? any ideas? Hopefully it's properly fixed in 5.3.7 whenever that comes out!
