bill999
Jul 05, 2012Aspirant
How: to Format a hard drive taken from NasDuo
Hi I have just upgraded my 1tB hard drives to 2TB hard drives in the NasDuo. I now want to format the old hard drives to use in a pc or external hard drive caddy, but how do I do this. I have place...
Jul 05, 2012Guru - Experienced User
You need to reformat it for Windows.
With Windows 7, you go into control panel and launch computer management. When you look at "disk management" you should see the disk there. Delete the partitions and reinitialize the disk. (Be very certain you are working with the correct drive!)
