mito1
Jan 18, 2012Aspirant
How to keep ssh-session alive?
Hi there,
i often copy a lot of large files from an USB-Share to the NAS or from the NAS to an USB Share. I use a ssh-connection and Midnight Commander because this is much faster than copy the files over ther LAN. But my PC must be "ON" all the time. If I close putty/ssh-session the Midnight Commander - and the copy process - is killed as well.
Is it possible to start the ssh-session or MC on a way that I can shutdown my PC, but the MC will work in the background. And later I start my PC an connect again to it. I hope you understand what I mean :)
- mdgm-ntgrNETGEAR Employee RetiredSchedule MC to run using a cron job. You can place a file in /etc/cron.d containing the schedule you want to schedule it to run.
- mito1AspirantOhh, I think explained it not clear. I don't need cron-jobs, because these are not periodically copy jobs.
I'll get an USB-HDD, connect it to my NAS, start Windows, putty, MC and copy the files from the USB-HDD to the NAS. Let's say it will take ~ 4 hours. Now I will shutdown my PC, but MC should be remain working on the NAS ... - mdgm-ntgrNETGEAR Employee RetiredUsing something like cron you can schedule a command to run in the background. I don't know if this works with mc. You can schedule a job to run and then delete the cron entry once the job is finished.
I believe you can do some midnight commander stuff as a background job. Not sure how to do this but you can search for info. - mito1AspirantO.K. thanks for the info.
I found something about "screen". Maybe this could run on my NAS and help me. I will take a look at that. - mdgm-ntgrNETGEAR Employee RetiredMaybe take a look at this thread: http://www.readynas.com/forum/viewtopic.php?f=11&t=23244
- ripfaceAspirantYou can use the at command to run a script in the background.
eg: $at now <script name>
This will start the script in the background as a batch job so you can safely log out and the job will continue.
Cheers,
Ripface - mito1AspirantMy friend is screen I think 8)
Installation:apt-get install screen
Login over ssh, starting screen at the promptscreen
Press Enter or space to close Dialog. Then work with the following commands. Every command starts with a [Strg a] and the program waits for a parameter. For example:[Strg-a] c
[Strg-a] [c] - screen - opens a new virtual window
[Strg-a] [space] - next - changes to next window
[Strg-a] [d] - detach - set the screen "free", current processes keep on running. You can logout and close ssh-connction now.
Next ssh-session you type on the promptscreen -r
and the screen is recalled.
[Strg-a] [K] - kill - Kills the screen session: Really kill this window [y/n]
HTH
mito
