diamondminer
Jan 15, 2016Aspirant
How to make an exact copy of a share using backup or rsync
I have a ReadyNAS Ultra 2 [X-RAID2] (call this "main") as my main file server and a ReadyNAS Duo [X-RAID] as my backup server (call it "backup"). I have been running a reguler backup routine from "m...
- Jan 16, 2016
diamondminer wrote:
Which method is better - backup (pushing "main' to "backup") or rsync ( pulling "main" to "backup")?rysnc can be used to both "push' and "pull" (and you'll need rsync to get the exact copy you want). Both methods work equally well. I am backing up to multiple NAS, and it is a bit easier to manage "pull" (it eliminates having muliple backup jobs for the same share on the main NAS).
diamondminer wrote:
How does the compression function wok?
It compresses the data flowing on the network connection. It is not compressing the files. If the backup is on the local lan, I'd just leave it off.
Jan 15, 2016Guru - Experienced User
With rsync in particular, there's a backup option that does what you want. It's called "Remove deleted files on source.", and is a check box in the "step 1" pane.
For other protocols, that option isn't available. You can choose to check the "Remove the contents of the backup destination before a full backup is performed." option in step 4 (at the bottom), and schedule an full backup from time to time. The risk is that main NAS happens to fail in the middle of the full backup, you'll lose data.
diamondminer
Jan 16, 2016Aspirant
Thanks,
Which method is better - backup (pushing "main' to "backup") or rsync ( pulling "main" to "backup")? How does the compression function wok? does it compress all files or jsut those that are added on teh backup routine? If this is true, how would I compress all files on "backup"?
- StephenBJan 16, 2016Guru - Experienced User
- diamondminerJan 16, 2016Aspirant
Awesome! Thank you for clarifiying for me.
Frank
