diamondminer's avatar
diamondminer
How to make an exact copy of a share using backup or rsync
I have a ReadyNAS Ultra 2 [X-RAID2] (call this "main") as my main file server and a ReadyNAS Duo [X-RAID] as my backup server (call it "backup").  I have been running a reguler backup routine from "m...
  • StephenB's avatar
    Jan 16, 2016
    diamondminer wrote:
     Which method is better - backup (pushing "main' to "backup") or rsync ( pulling "main" to "backup")?
    rysnc can be used to both "push' and "pull" (and you'll need rsync to get the exact copy you want).  Both methods work equally well.   I am backing up to multiple NAS, and it is a bit easier to manage "pull" (it eliminates having muliple backup jobs for the same share on the main NAS).
    diamondminer wrote:
     How does the compression function wok?
    It compresses the data flowing on the network connection.  It is not compressing the files.  If the backup is on the local lan, I'd just leave it off.
ProSupport for Business
