russrtw1
Feb 11, 2010Aspirant
How to restore a backup iSCSI Target with Frontview??
I just performed a factory-reset on my NVX, running 4.2.9 firmware. I went to restore my previous iSCSI target data that is written to the USB hard drive attached to the NVX... but I don't see any wa...
russrtw1
I was turned away from the manual copy of the backup iSCSI file because of "LUN/ID problems after copying" (so the Netgear support rep stated). Have you performed this restore yourself and confirmed it works? Is there any concern if during the backup file copy, the iSCSI service is running? And also, I'm assuming that the iSCSI file name name has to match the one you're configured in the iSCSI volume tab in frontview.
DBott - you are the man. Thanks for such detailed instructions. Now only if I could login via RootSSH (still waiting for responses from others on that one). Nice blog/webpage by the way. You've got a killer home and biz ReadyNAS setup.
