augur
Mar 28, 2016Apprentice
How to set iSCSI CHAP Username with OS6
Hi. I upgraded my Ready NAS Pro 4 to Ready OS6 (thanks to Netgear, great support!!!) and like to use CHAP on my iSCSI connection to a debian VM. Before with OS4 I can set a username bit with OS6 ...
- Apr 04, 2016
Hi augur,
The username is the same as the local system initiator name set by your iSCSI initiator or the one's set under the IQN (initiator name). Try that and tell me if that works.
Kind regards,BrianL
NETGEAR Community Team
BrianL2
Mar 28, 2016NETGEAR Employee Retired
Hi augur,
Welcome to the community!
You can still manually set your iSCSI initiator username but it does have a different character requirement. I suggest that you check this article to set it up properly.
Kind regards,
BrianL
- augurApr 02, 2016Apprentice
Hi Brian,
I read this article before but it is for windows only. But perhaps you can comment the following:
This are the settings I have to enter in webmin to setup CHAP. What is the username shown here? In OS4 I have to enter name and password. In OS6 the username is missing. Or is it perhaps same as the IQN?
Cheers,
Nils
- BrianL2Apr 04, 2016NETGEAR Employee Retired
Hi augur,
Kind regards,BrianL
NETGEAR Community Team- augurApr 05, 2016Apprentice
Hi.
Connected successfully with CHAP. :-) During my test I used also bidirectional CHAP authentification (second missconfiguration) but also now with your hint for the username it is working fine again.
Thanks a lot!
Nils
