patrickriley201
Jan 07, 2014Aspirant
How to set up a UPS
Im no networking expert and have hardly any idea what I am doing. First off i would like to know how to how to set up my APC 550VA. Will it work if i just pass the ethernet from the modem to my Netgea...
patrickriley201
Jan 21, 2014Aspirant
fastfwd wrote:
patrickriley2010 wrote: i would like to know how to how to set up my APC 550VA. Will it work if i just pass the ethernet from the modem to my Netgear Nighthawk AC1900 through the APC pass through or would i do it between the the Netgear Nighthawk AC1900 and my ReadyNas102?
The pass-through is for a telephone line, not an Ethernet cable.
patrickriley2010 wrote: Or do I have to use the USB?
Yes, use the USB. The UPS should have come with a special cable: USB A connector on one end, 8P8C connector (Ethernet connector) on the other. Connect that cable between the correct port on the UPS and one of the USB ports on the NAS.
patrickriley2010 wrote: I dont know what to put in the address section
The UPS should be automatically recognized; it won't be using the SNMP protocol, so you won't need to enter an SNMP address.
Thanks i just really was hoping i could use something else instead of using one my my usb ports. And my UPS has ethernet passthrough, I know because I have them plugged into it.
