warren18
Nov 19, 2020Aspirant
How to set up my networks to access my NAS with ReadyCloud
I recently moved over to Europe and plugged my stuff back in but now I can't access my NAS with Readycloud. Prior to the move, I had my ReadyNAS connected to my Spectrum Cable modem and my Orbi rout...
JohnCM_S
Nov 19, 2020NETGEAR Employee Retired
Hi warren18,
May I know the model number of your ReadyNAS?
You may check first the Internet and Service status of the NAS. You can do that by logging in to the local admin page of the NAS then go to the Cloud tab. Both the Internet and Service should have a green check on them On the same tab, you can also check there if the ReadyCLOUD service is enabled or not.
warren18
JohnCM_S wrote:Hi warren18,
Thanks for the quick reply
My model number is a RN31400 Firmware 6.10.3
Under the cloud tab it says internet not available. The ReadyCloud service is on/Green
