joe_wht
May 16, 2016Luminary
How to setup CUPS on ReadyNAS 214, so I can remote print to Brother Printer
I'm looking for the CUPS app that will let me use my Brother printer when I'm away from home. I never use my Desktop.. so I'm hoping to leave it & my laptop OFF and just have the printer wired to t...
JennC
May 17, 2016NETGEAR Employee Retired
Hello joe_wht,
Currently, the add-ons/apps listed at ReadyNAS Apps are the ones submitted to NETGEAR to work with ReadyNAS OS6 units.
Support for printers on USB ports of ReadyNAS has been removed from ReadyNAS OS6. Probably the one you saw is for OS4 or OS5.
You may also post suggestions and ideas at Idea Exchange board. Adding kudos to the ideas will help as development team will be reviewing the post that has the most kudos for considering it to add to the product's future functionality.
- StephenBMay 17, 2016Guru - Experienced User
There is a CUPS download in super_poussin's drop box here: https://community.netgear.com/t5/Current-NETGEAR-and-Partners/Addons-available-For-R6/td-p/842756. But the CUPS drivers folder only contains x64, so that download won't work with the RN214.
- mdgm-ntgrMay 17, 2016NETGEAR Employee Retired
Perhaps the AirPrint app would be worth a try: https://rnxtras.com/addons/rnairprint-readynas-6-all
