joe_wht
May 16, 2016Luminary
How to setup CUPS on ReadyNAS 214, so I can remote print to Brother Printer
I'm looking for the CUPS app that will let me use my Brother printer when I'm away from home. I never use my Desktop.. so I'm hoping to leave it & my laptop OFF and just have the printer wired to t...
WhoCares_
May 18, 2016Mentor
What download did you find and why wouldn't it work with the 214?
joe_wht
May 18, 2016Luminary
I could only find drop box for x64.. nothing for the ReadyNAS 214 (212) OS arm
arm (version 6.5.0) for RN102 / RN104 / RN202 / RN204 / RN212 / RN214 / RN2120
x86 (version 6.5.0) for RN312 / RN314 / RN316 / RN516 / RN716x / RN3130 / RN3138 / RN3220 / RN4220
- WhoCares_May 18, 2016Mentor
You mean the addons provided by SuperPoussin in his dropbox?
- joe_whtMay 18, 2016Luminary
Yes.. I treid his... and I found 2 or 3 other apps ( so called print servers ) but they was for the Duo.
When I chatted with a Netgear tech he only 2 ( air print & the x64 CUPS)
HOWEVER, He knews (he's heard of) something out there working on the 104's & 212's.
- WhoCares_May 25, 2016Mentor
The major problem with setting up a remote printer on the RN214 most likely will be finding matching drivers for your printer on the ARM CPU platform. Brother only provides a driver suite for the Intel x86 platform and doesn't make the source code available. That's in line with what most major printer/scanner vendors do, unfortunately.
