Retired_Member
Jun 08, 2011How to setup mySQL and PHP on an Ultra 2
Just bought an Ultra 2 (RNDU2220) system (2x2TB) and wonder after browsing through the board which add-ons and Debian packages to combine for PHP/SQL + phpMyAdmin. Is there any "best practice" know...
mdgm-ntgr
Jun 08, 2011NETGEAR Employee Retired
First I would suggest you install the x86 EnableRootSSH add-on (see http://www.readynas.com/?p=4203). This way if you have a problem you can fix it using SSH.
To turn on MYSQL you can use this add-on: http://www.readynas.com/forum/viewtopic.php?f=48&t=22853
Then you'll need to install a PHP add-on e.g. WhoCares's PHP 5.2 add-on: http://www.readynas.com/forum/viewtopic.php?f=48&t=35881
Then the PHPMyAdmin add-on: http://www.readynas.com/forum/viewtopic.php?f=48&t=22713
