Bobknds's avatar
Bobknds
how to update to OS6? Is it possible?
Netgear sent me an email recommending upgrading, said:
The Vulnerability:
NETGEAR has become aware of the Badlock security vulnerability that causes ReadyNAS OS 6 devices to be susceptible to man-in-the-middle (MiTM), denial of service (DoS), and similar attacks. Our records indicate that your NETGEAR product is affected.
What You Can Do:
NETGEAR strongly recommends that you install firmware version 6.5.0 that was released on May 17, 2016.
 I stil have RAIDAR 4.3.8  and firmware 4.2.28 and running x86. Not sure what to download and install, any help would be greatly
Appreciated.
  • kohdee's avatar
    kohdee
    Administrator
    Upgrade to OS 6 is possible but unsupported by NETGEAR Support. There are threads here that could help you but it is at your own risk and requires a factory default.
    • Bobknds's avatar
      Bobknds
      Hi,
      Thanks for the response, so it would wipe all my data to do an update to OS6?  And am I at risk if I do not update to OS6?
      Bob
      • BrianL2's avatar
        BrianL2
        NETGEAR Employee Retired
        Hi Bobknds,
        Welcome to the community!
        You should first make a backup of your data before starting the upgrade. Check this page for instructions and open the ReadyNAS forum threads for additional tips & instructions.
        Kind regards,
        BrianL
        NETGEAR Community Team
  • kohdee's avatar
    kohdee
    Administrator
    Not sure why you received this as an e-mail -- I checked your registered products based on the e-mail that you use here on the Community and I only see your Ultra 2... so you should not have received this alert... I will check into this.
    • kohdee's avatar
      kohdee
      Administrator
      Regarding the notice, it was erroneously sent to all ReadyNAS models, instead of all OS 6 models. Apologize for this!
ProSupport for Business
