Retired_Member
Mar 28, 2017How to upgrade firmware of an HDD, which is part of a RAID array in a ReadyNAS?
Assume you need to upgrade the firmware of an HDD, which is part of a RAID array in a ReadyNAS. How I would do it: (1) Shutdown the nas and (2) completely separate it from power. (3) Remove the c...
- Retired_MemberMar 28, 2017
Thanks; it seems, that beyond removing the HDD there is no other way.
mdgm-ntgr
Mar 28, 2017NETGEAR Employee Retired
You would need to remove the disk from the NAS. It's possible an external enclosure may not be compatible with the firmware update tool.
The tool to update the firmware on the HDD probably comes with a disclaimer that your data may be lost. In any case it is advisable to update your regular backup first.
