thsciguy
Feb 09, 2014Aspirant
I revived my ReadyNAS NV+ v1 after 2 years, now what?
My PSU for my ReadyNAS NV+ died about 2+ years ago and due to "life" happening I haven't gotten around to getting a new PSU and bringing it back to life. Right now it has all my FLAC music files on i...
vandermerwe
Feb 09, 2014Master
Do you know when your unit was last factory defaulted?
There was a file system block size change when firmware hit 4.x.x. You should be on an early version of this but it's important to know if the unit has been factory defaulted on 4.x.x.
The firmware that you need is 4.1.13:
viewtopic.php?f=17&t=74130
There haven't been any major changes in the last 2 years as the nv+ is an old readynas unit and the firmware updates really only involve bug fixes.
As for your second questions, I don't stream to those devices but there is a lot on the forums about them.
You should have a backup of the data - re-ripping a lot of music if you lose data would be very time consuming.
Ideally sort out a backup before you upgrade firmware.
