hokieguy
Dec 11, 2012Aspirant
Identifying a failing drive
Hi all, I'm running an original NV with 3x1TB drives. In the last day or so, one of the drives has gotten pretty noisy - it sounds almost like a drive is constantly running and the normal noise th...
hokieguy
Dec 12, 2012Aspirant
Thanks, I suspected Drive 2 was the bad one, as well - based on what you pointed out, also it's the oldest drive by far. I suppose I can't complain when the drive has over 4.5 years of nearly 24x7 use on it! A new WD Red is on the way as a replacement.
