hokieguy
Dec 11, 2012Aspirant
Identifying a failing drive
Hi all, I'm running an original NV with 3x1TB drives. In the last day or so, one of the drives has gotten pretty noisy - it sounds almost like a drive is constantly running and the normal noise th...
gibxxi
Dec 12, 2012Guide
This is also a SMART value you should note with concern:
Reallocated Sector Count 11
That value indicates sectors that have ALREADY gone bad and have been reallocated with spare sectors by the drive itself. As soon as you see this value go above 0, you need to keep an eye on it and budget for a replacement ASAP.
