hokieguy
Dec 11, 2012Aspirant
Identifying a failing drive
Hi all, I'm running an original NV with 3x1TB drives. In the last day or so, one of the drives has gotten pretty noisy - it sounds almost like a drive is constantly running and the normal noise th...
hokieguy
Jan 17, 2013Aspirant
mdgm wrote: When you hot-add a drive the ReadyNAS wipes it and adds it to the array.
OK so the resync is normal then.
Is there a better way? Let it boot fully on 2 drives, shut down, re-add the 3rd drive while off?
