jonathansmall
Jan 17, 2012Follower
iMac drops connection to Readynas device
I have 3 readynas devices connected via ethernet to a switch. My iMac is connected to the switch as well. The iMac sees all 3 readynas devices in finder. When I open finder and navigate to a .m4v v...
mdirvin
Feb 02, 2012Aspirant
Just a thought. I had the same problem, my MacPro would drop connections with my ReadyNAS Pro 4. The problem turned out to be my network settings on my Mac. I had the hardware setting form the ethernet connection set manually, along with the jumbo frames set to 9000. After setting the hardware settings to automatic the problem went away. A simple solution in my case. Mike
