akr
Aug 20, 2014Aspirant
Incomplete Frontview NV+ reinstall FW didn't help
Hi Forum My 7 year old NV+ doesn't show the Frontview anymore. Just a very incomplete page. I can't mount my shares, as I think NFS and SMB service aren't running. No access to all data. The RAI...
Aug 20, 2014Guru - Experienced User
You took a risk with the USB install.
Did the NAS misbehave before this started? For instance, locking up or disconnecting from the network? It sounds a bit like a full OS partition.
If so it can be corrected remotely. mdgm might be able to give advice on how.
Also, what browser are you using?
- Jul 15, 2018Retired_Member
