CJDEN
May 30, 2020Apprentice
Incorrect serial no on ReadyNas 6 Pro / can't access ReadyCloud
Hi, I just got hold of a second hand ReadyNas Pro 6 (RNDP6310). It's running software version 6.10.3 however when I wanted to connect it to ReadyCloud as my other 2 ReadyNas's, it returns the mes...
- May 30, 2020
Hi CJDEN,
The fix has been applied and the NAS has been rebooted. Please check if it has the correct serial number now.
JohnCM_S
May 30, 2020NETGEAR Employee Retired
Hi CJDEN,
Please take a picture of the sticker label that contains the serial number and MAC address then provide it to me via private message. This is located on the rear panel of the chassis.
Enable also the Secure Diagnostic Mode (SDM). You can enable it by going to System > Settings Support, then provide to me the 5-digit port number.
