CJDEN's avatar
CJDEN
Apprentice
May 30, 2020
Incorrect serial no on ReadyNas 6 Pro / can't access ReadyCloud
Hi,   I just got hold of a second hand ReadyNas Pro 6 (RNDP6310). It's running software version 6.10.3 however when I wanted to connect it to ReadyCloud as my other 2 ReadyNas's, it returns the mes...
  • JohnCM_S's avatar
    May 30, 2020
    Hi CJDEN,
    The fix has been applied and the NAS has been rebooted. Please check if it has the correct serial number now.
ProSupport for Business
