AndreasKa
Dec 19, 2014Tutor
Increase Performance with mdadm variables
Hi All, I'm hotly anticipating delivery of my ReadyNas 314 unit and also reading about the risks associated with high RAID5 rebuilt times when using multi-TB drives and arrays. I was wondering ...
mdgm-ntgr
Dec 19, 2014NETGEAR Employee Retired
I'm not sure whether such changes would help syncing speed on the 314 or not.
You should note that the volume is redundant throughout the initial sync.
I would recommend you backup your data. No important data should be stored on just the one device.
