milks
Feb 16, 2015Tutor
Increasing reallocated sector count but SMART says good...
Hey I swapped out one of the disks in my Ultra2 a couple of weeks ago because of the following warnings: Detected increasing reallocated sector count[14762] on disk 2 [ST32000542AS, 5XW1F84...
Feb 19, 2015Guru - Experienced User
The threshold for failure in the vendor diagnostics is higher than my personal threshold. Seatools will certainly pass with more bad sectors than I am comfortable with, so you should review the SMART stats again.
Command Timeouts are a bit hard to sort out, but if they are increasing on one drive and you have the same drives in the NAS with no timeouts, then that is a clue that something is wrong.
