rg807
Feb 19, 2013Aspirant
Indexing/Share access for My Documents
Hi, I'm running Win7 and on my old ReadNAS I had the My Documents folder for each user mapped directly to the NAS. I now have a new Ultra and I need to do the mapping again but when I attempt this ...
Feb 20, 2013Guru - Experienced User
/d has nothing to do with your "d" drive. it tells mklink to that you are creating a symbolic directory link (instead of a symbolic link to a file). Creating a partition is not needed (and not relevant).
If you type mklink directly into the CMD prompt, are you still getting the ""the system cannot find the path specified" message? That is, just mklink - nothing else.
- May 12, 2025Retired_Member
