dhl
Dec 05, 2013Luminary
Inexpensive NAS for over 4TB backups - recommendations?
To date, we've backed up our ReadyNAS Pros using cheap USB drives. This has served us well over the past three years but as we move forward to much larger disks and volume capacity, I'm rethinking thi...
dhl
Jan 07, 2014Luminary
The upgrade on our LA-based Pro system is complete and I've begun backing up to our 104 backup NAS.
I set up two backup jobs:
Job 1)
source - volume C (ReadyNAS Pro)
destination - remote NSF volume /data/Backup (on the ReadyNAS 104)
Job 2)
destination - remote RSYNC volume Backup (on the ReadyNAS 104)
I tested and verified both jobs were set up and working properly
I ran Job 1 as a full backup. It took about three days and then failed with an unknown error. There is no information in Job 1 log on the cause of the error. I checked the backup volume on the 104 and 2.94GB of 3.06GB has been successfully copied. I did a spot verification of the files and they all seem good. All critical shares and directories seem to have been backed up fully.
I don't know why NSF failed but the 104 is still responsive and at less than 50% capacity. I also upgraded to 6.1.5 before starting this process.
Since 90% of the backup was complete, I started the RSYNC job to initiate regular incremental backups.
Questions -
When setting up a backup job, it appears that a full backup must be performed at least once at the start. According to my logs, RSYNC is doing a full back-up but is first sending an incremental file list of every file in volume C.
Is this normal?
Is RSYNC actually doing a full back-up all over again? Or is it simply building a list to compare against what's already on the backup NAS? I'm hoping it copies only the files that didn't get copied with the first NSF backup.
Thanks!
Job 1)
Job 2)
Questions -
Is this normal?
Thanks!
