dhl
Dec 05, 2013Luminary
Inexpensive NAS for over 4TB backups - recommendations?
To date, we've backed up our ReadyNAS Pros using cheap USB drives. This has served us well over the past three years but as we move forward to much larger disks and volume capacity, I'm rethinking thi...
xeltros
Jan 08, 2014Apprentice
It depends on what command you use.
for SCP it's host:/path.
for SMB it's //host/path.
man rsync suggest an FTP-like path : rsync [OPTION]... rsync://[USER@]HOST[:PORT]/SRC [DEST]
The script fast fwd sent will work if you mounted the distant volume. Otherwise you can do on each NAS then use scp to copy from one to the other.
