dhl
Dec 05, 2013Luminary
Inexpensive NAS for over 4TB backups - recommendations?
To date, we've backed up our ReadyNAS Pros using cheap USB drives. This has served us well over the past three years but as we move forward to much larger disks and volume capacity, I'm rethinking thi...
dhl
Jan 08, 2014Luminary
xeltros wrote: Otherwise you can do on each NAS then use scp to copy from one to the other.
This is what I wound up doing - easier than trying to remotely mount the distant volume.
And the results show that except for a handful of invisible files, source and destination are the same. I did a spot check of one of the invisible directories (a subsonic folder in .webroot) and found it was 180mb. My guess is permissions may have caused the NSF full backup to fail and this along with some of the other invisible files is why I'm see a data size difference between my source and the backup.
Whatever the cause, I'm confident the backup is good and everything's in order.
Thanks @fastfwd and @ xeltros for the shell tips. Always glad to learn! :thumbsup:
