dhl
Dec 05, 2013Luminary
Inexpensive NAS for over 4TB backups - recommendations?
To date, we've backed up our ReadyNAS Pros using cheap USB drives. This has served us well over the past three years but as we move forward to much larger disks and volume capacity, I'm rethinking thi...
dhl
Jan 10, 2014Luminary
StephenB wrote: The RN102 is running rsync backup jobs running daily to back up shares on my pro-6.
Is it possible to select volume C on the Pro as the Rsync backup source from OS6 on the 102? I tried this on the 104 and couldn't find a way to specify volume C. Maybe I missed something simple?
xeltros wrote: I believe snapshots are done by midnight (mine are at least according to logs), so this won't affect the work hours productivity and will be transparent for users. You can give them access to snapshots via a shared folder or choose not to and keep the access in the web interface only.
If that's the case, I wonder if snapshots would still work if the backup NAS is automatically powered on and off? (btw, I tested sending WOL from Frontview on the Pro and it works great.)
