dhl
Dec 05, 2013Luminary
Inexpensive NAS for over 4TB backups - recommendations?
To date, we've backed up our ReadyNAS Pros using cheap USB drives. This has served us well over the past three years but as we move forward to much larger disks and volume capacity, I'm rethinking thi...
Mar 27, 2014Guru - Experienced User
snapshots are very different on the pro, and I believe there is no way to modify the behavior.
BTW, I am using rsync to backup shares on my pro-6 to an RN102. The RN102 runs 6.1.6, has snapshots enabled, and removes files not on the source (similar to yours).
I haven't seen the unlink errors you report above. I am wondering if something more fundamental is wrong. Have you tried support?
