dhl
Dec 05, 2013Luminary
Inexpensive NAS for over 4TB backups - recommendations?
To date, we've backed up our ReadyNAS Pros using cheap USB drives. This has served us well over the past three years but as we move forward to much larger disks and volume capacity, I'm rethinking thi...
dhl
Mar 28, 2014Luminary
StephenB wrote: snapshots are very different on the pro, and I believe there is no way to modify the behavior.
Good to know. I guess we won't use it then. I don't want folks accidentally opening and saving to the "-snap" shares. And I know they will! :wink: Seems like snapshots are pretty kludgy on the Pro. Am I missing something?
StephenB wrote: BTW, I am using rsync to backup shares on my pro-6 to an RN102. The RN102 runs 6.1.6, has snapshots enabled, and removes files not on the source (similar to yours).
I haven't seen the unlink errors you report above. I am wondering if something more fundamental is wrong. Have you tried support?
Are you running the backup from the Pro-6 source or the RN102 target? And are you backing up shares or the volume? Last I checked, OS6 didn't allow choosing volume C as a remote Rsync backup source. So we're forced to run the backup from the Pro. Per your recommendations, I'd prefer running our backup from our RN104. I'll check and see if it'll work the way we want in 6.1.6.
I haven't checked with support as I find these forums very helpful but that's a good idea as well.
