kesch
Jan 09, 2019Aspirant
Initial setup
I need a link to the setup software. I have the RAIDar utility which verifies that the 2x2TB drives are correctly formated and the NAS Duo V2 is ready and properly connecte. The 5.3 SW manual that ...
- Jan 15, 2019
Hi kesch,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The NETGEAR community looks forward to hearing from you and being a helpful resource in the future!
Jan 10, 2019Guru - Experienced User
There is none. You browse to http://nas-ip-address/admin or http://nas-name/admin to do the setup (using the real NAS ip address or host name).
The RAIDar utility can provide some useful information. Version 4.3.8 is needed for enable flexraid (the only exception to the "no setup software" rule), but you can use 6.4 if you aren't doing that. https://kb.netgear.com/20684/ReadyNAS-Downloads#raidar
There are two quite different Duo platforms - the original Duo (called a Duo v1 here), and the Duo v2. You do need to be careful on platform identification - the labeling can be misleading.
A Duo v1
- runs 4.1.x firmware
- says ReadyNAS Duo on the front panel
- might have v2 labels on the rear or bottom.
A Duo v2
- runs 5.3.x firmware
- says ReadyNAS Duo v2 on the front panel
RAIDar does report these correctly, so you can use it to confirm the platform.
