kesch
Jan 09, 2019Aspirant
Initial setup
I need a link to the setup software. I have the RAIDar utility which verifies that the 2x2TB drives are correctly formated and the NAS Duo V2 is ready and properly connecte. The 5.3 SW manual that ...
- Jan 15, 2019
Hi kesch,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The NETGEAR community looks forward to hearing from you and being a helpful resource in the future!
kesch
Jan 10, 2019Aspirant
Thanks!! But when I went to my for the ReadyNAS IP 192.168.1.12/admin, it asked for a user ID and password. I don't know what IDs or password is required? Any ideas?
JohnCM_S
Jan 10, 2019NETGEAR Employee Retired
Hi kesch,
If your NAS is a Duo v1 the default admin credentials is admin for username and netgear1 for password. If is a Duo v2, the default admin credentials is admin for username and password for password.
In case that did not work, the admin password might have been changed. You can change it back to default by doing an OS reinstall. Here is the link for the steps on how to access the boot menu and select the OS reinstall:
Duo v1
https://kb.netgear.com/24874/How-do-I-access-the-boot-menu-on-my-ReadyNAS-Duo-NV-NV-X6-or-600
Duo v2
