kesch
Jan 09, 2019Aspirant
Initial setup
I need a link to the setup software. I have the RAIDar utility which verifies that the 2x2TB drives are correctly formated and the NAS Duo V2 is ready and properly connecte. The 5.3 SW manual that ...
- Jan 15, 2019
Hi kesch,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The NETGEAR community looks forward to hearing from you and being a helpful resource in the future!
kesch
Jan 10, 2019Aspirant
Thanks!! But when I went to my for the ReadyNAS IP 192.168.1.12/admin, it asked for a user ID and password. I don't know what IDs or password is required? Any ideas?
JohnCM_S
Jan 15, 2019NETGEAR Employee Retired
Hi kesch,
