ronaldvr2132
Oct 02, 2018Apprentice
Instable SMB connection to shares
Since I upgraded to firmware 6.9.4 I have a lot of problems to have stable connections. I already mentioned iSCSI problems. but also my SMB shares are very instable. Is this a know issue of firmware 6.9.4 in combination with a RN628X. Is there a way to go back in firmware version so that I can go back to a reliable solution?
Per the release notes, you can downgrade to 6.9.0 - 6.9.3.
- Retired_Member
Hi ronaldvr2132, did you follow the downgrade path as mentioned by StephenB and if yes, did that fix your issues?
Kind regards
