ronaldvr2132
Oct 02, 2018Apprentice
Instable SMB connection to shares
Since I upgraded to firmware 6.9.4 I have a lot of problems to have stable connections. I already mentioned iSCSI problems. but also my SMB shares are very instable. Is this a know issue of firmware 6.9.4 in combination with a RN628X. Is there a way to go back in firmware version so that I can go back to a reliable solution?
- Anonymous
Hi ronaldvr2132, did you follow the downgrade path as mentioned by StephenB and if yes, did that fix your issues?
Kind regards
Per the release notes, you can downgrade to 6.9.0 - 6.9.3.
