Kaleem
Oct 06, 2014Aspirant
Installation / HDD Firmware Upgrade
Hi, I need some advice on setting up a ReadyNAS from scratch. Kit: ReadyNas NV +V2 (disk less) 4 x 3TB Seagate HDD I'm running a Win 8.1 setup with a NETGEAR Nighthawk AC1900 Dual Band Wi...
vandermerwe
Oct 06, 2014Master
Did you look for information about upgrading the firmware?
http://knowledge.seagate.com/articles/e ... Q/223651en
The readynas will not change the firmware on the drives.
What firmware is running on the readynas?
What does the volume information say about the disks and volume?
The drives you are using are on the HCL but there are many users that have problems with them.
Did you remove an re-add the drive while the nas was on or off?
If the latter, try removing while on then reinserting while on.
If that doesn't work, reboot ( perhaps a few times) and see of the volume expands.
