Kaleem
Oct 06, 2014Aspirant
Installation / HDD Firmware Upgrade
Hi, I need some advice on setting up a ReadyNAS from scratch. Kit: ReadyNas NV +V2 (disk less) 4 x 3TB Seagate HDD I'm running a Win 8.1 setup with a NETGEAR Nighthawk AC1900 Dual Band Wi...
Kaleem
Oct 11, 2014Aspirant
I appear to be up and running now......
I took out one of the drives that seemed to have an older Firmware version, stuck it in my PC and upgraded the Firmware via USB Boot Disk.
Then stuck it back in the ReadyNas and carried out a factory default, which installed everything from scratch and created a Volume size 8.1TB (for 4 x 3TB drives in X-RAID mode)
Thanks for your help guys.
I'm sure I will be back with some other type of issue, now that I will start using the ReadyNAS properly !!!
