Bofc
Jul 05, 2017Aspirant
intermittent lockups readynas pro 4 on firmware 6.7.5
hello, i know there is no support with the lagacy readynas pro 4 running firmware 6+, but figured i would let you know of an issue i have been having. upgraded to firmware 6.7.5 from 4+ and have been...
jak0lantash
Jul 05, 2017Mentor
You could download the logs from the UI and look into dmesg.log.
It could be that the data is heavily fragmented due to bit rot protection (which means Copy-on-Write) and trying to decrypt that.
Also check the metadata allocation in btrfs.log.
