Bofc
Jul 05, 2017Aspirant
intermittent lockups readynas pro 4 on firmware 6.7.5
hello, i know there is no support with the lagacy readynas pro 4 running firmware 6+, but figured i would let you know of an issue i have been having. upgraded to firmware 6.7.5 from 4+ and have been...
jak0lantash
Jul 05, 2017Mentor
You could download the logs from the UI and look into dmesg.log.
It could be that the data is heavily fragmented due to bit rot protection (which means Copy-on-Write) and trying to decrypt that.
Also check the metadata allocation in btrfs.log.
Bofc
Jul 06, 2017Aspirant
here are those two files, i see where there are "out of memory" notices, but it seems to kill the process and continues to run. where as when it hangs, nothing works except a hard power reset. well looks like i cant attach the files, so here is a part of the logs:
dmesg.log
[Thu Jul 6 04:10:40 2017] Mem-Info:
[Thu Jul 6 04:10:40 2017] active_anon:80 inactive_anon:138 isolated_anon:0
active_file:59749 inactive_file:106860 isolated_file:276
unevictable:0 dirty:110409 writeback:3918 unstable:0
slab_reclaimable:22507 slab_unreclaimable:15787
mapped:5254 shmem:4 pagetables:2075 bounce:0
free:6320 free_pcp:186 free_cma:0
[Thu Jul 6 04:10:40 2017] DMA free:4012kB min:316kB low:392kB high:472kB active_anon:0kB inactive_anon:0kB active_file:68kB inactive_file:412kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:15972kB managed:15888kB mlocked:0kB dirty:412kB writeback:0kB mapped:0kB shmem:0kB slab_reclaimable:6380kB slab_unreclaimable:1632kB kernel_stack:16kB pagetables:132kB unstable:0kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB writeback_tmp:0kB pages_scanned:2920 all_unreclaimable? yes
[Thu Jul 6 04:10:40 2017] lowmem_reserve[]: 0 959 959 959
[Thu Jul 6 04:10:40 2017] DMA32 free:21268kB min:19748kB low:24684kB high:29620kB active_anon:320kB inactive_anon:552kB active_file:238928kB inactive_file:426836kB unevictable:0kB isolated(anon):0kB isolated(file):1232kB present:1022656kB managed:987772kB mlocked:0kB dirty:441224kB writeback:15672kB mapped:21016kB shmem:16kB slab_reclaimable:83648kB slab_unreclaimable:61516kB kernel_stack:4208kB pagetables:8168kB unstable:0kB bounce:0kB free_pcp:744kB local_pcp:20kB free_cma:0kB writeback_tmp:0kB pages_scanned:4465512 all_unreclaimable? yes
[Thu Jul 6 04:10:40 2017] lowmem_reserve[]: 0 0 0 0
[Thu Jul 6 04:10:40 2017] DMA: 33*4kB (UE) 29*8kB (UE) 26*16kB (UME) 43*32kB (UME) 21*64kB (UME) 4*128kB (UE) 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 4012kB
[Thu Jul 6 04:10:40 2017] DMA32: 3009*4kB (UME) 600*8kB (UMEH) 25*16kB (UMEH) 0*32kB 1*64kB (H) 1*128kB (H) 1*256kB (H) 1*512kB (H) 1*1024kB (H) 1*2048kB (H) 0*4096kB = 21268kB
[Thu Jul 6 04:10:40 2017] 167062 total pagecache pages
[Thu Jul 6 04:10:40 2017] 166 pages in swap cache
[Thu Jul 6 04:10:40 2017] Swap cache stats: add 96986, delete 96820, find 127116/143802
[Thu Jul 6 04:10:40 2017] Free swap = 953448kB
[Thu Jul 6 04:10:40 2017] Total swap = 1046524kB
[Thu Jul 6 04:10:40 2017] 259657 pages RAM
[Thu Jul 6 04:10:40 2017] 0 pages HighMem/MovableOnly
[Thu Jul 6 04:10:40 2017] 8742 pages reserved
[Thu Jul 6 04:10:40 2017] [ pid ] uid tgid total_vm rss nr_ptes nr_pmds swapents oom_score_adj name
[Thu Jul 6 04:10:40 2017] [ 1453] 0 1453 29860 1517 28 3 132 0 systemd-journal
[Thu Jul 6 04:10:40 2017] [ 1471] 0 1471 10013 458 23 3 211 -1000 systemd-udevd
[Thu Jul 6 04:10:40 2017] [ 3026] 0 3026 8153 508 19 3 72 0 cron
[Thu Jul 6 04:10:40 2017] [ 3027] 84 3027 8056 324 22 3 85 0 avahi-daemon
[Thu Jul 6 04:10:40 2017] [ 3028] 83 3028 10173 593 24 3 150 -900 dbus-daemon
[Thu Jul 6 04:10:40 2017] [ 3029] 84 3029 8027 0 21 3 63 0 avahi-daemon
[Thu Jul 6 04:10:40 2017] [ 3031] 0 3031 5899 652 17 3 73 0 connmand
[Thu Jul 6 04:10:40 2017] [ 3032] 0 3032 1602 362 9 3 62 0 raidard
[Thu Jul 6 04:10:40 2017] [ 3033] 0 3033 3893 399 14 3 93 0 mdadm
[Thu Jul 6 04:10:40 2017] [ 3035] 0 3035 1068 362 8 3 33 0 noflushd
[Thu Jul 6 04:10:40 2017] [ 3036] 0 3036 6916 77 15 3 80 0 mdcsrepaird
[Thu Jul 6 04:10:40 2017] [ 3038] 0 3038 1586 347 8 3 57 0 wsdd2
[Thu Jul 6 04:10:40 2017] [ 3040] 0 3040 9399 364 22 3 148 0 systemd-logind
[Thu Jul 6 04:10:40 2017] [ 3050] 0 3050 13798 451 30 3 169 -1000 sshd
[Thu Jul 6 04:10:40 2017] [ 3089] 0 3089 9297 395 23 4 118 0 rpcbind
[Thu Jul 6 04:10:40 2017] [ 3099] 0 3099 31962 362 33 3 170 0 netatalk
[Thu Jul 6 04:10:40 2017] [ 3105] 0 3105 30578 744 62 3 353 0 afpd
[Thu Jul 6 04:10:40 2017] [ 3106] 0 3106 11859 708 27 3 132 0 cnid_metad
[Thu Jul 6 04:10:40 2017] [ 3128] 79 3128 9320 407 23 3 146 0 rpc.statd
[Thu Jul 6 04:10:40 2017] [ 3143] 0 3143 4881 405 12 3 39 0 agetty
[Thu Jul 6 04:10:40 2017] [ 3147] 0 3147 4836 463 14 3 38 0 agetty
[Thu Jul 6 04:10:40 2017] [ 3223] 0 3223 56891 638 107 4 457 0 nmbd
[Thu Jul 6 04:10:40 2017] [ 3229] 0 3229 34593 596 72 3 974 0 apache2
[Thu Jul 6 04:10:40 2017] [ 3238] 0 3238 82363 1010 154 3 684 0 smbd
[Thu Jul 6 04:10:40 2017] [ 3240] 0 3240 80216 532 144 3 686 0 smbd-notifyd
[Thu Jul 6 04:10:40 2017] [ 3241] 0 3241 80221 467 142 3 673 0 cleanupd
[Thu Jul 6 04:10:40 2017] [ 3242] 0 3242 385265 2273 165 5 12363 -1000 readynasd
[Thu Jul 6 04:10:40 2017] [ 3594] 0 3594 32478 433 28 3 129 0 fvbackup-q
[Thu Jul 6 04:10:40 2017] [ 3628] 0 3628 1589 270 8 3 31 0 minissdpd
[Thu Jul 6 04:10:40 2017] [ 3629] 1 3629 8374 462 19 3 72 0 upnphttpd
[Thu Jul 6 04:10:40 2017] [ 5746] 0 5746 12443 439 26 3 423 0 proftpd
[Thu Jul 6 04:10:40 2017] [ 5755] 0 5755 4423 476 13 3 48 0 rsync
[Thu Jul 6 04:10:40 2017] [ 5773] 0 5773 6379 0 16 3 59 0 rpc.idmapd
[Thu Jul 6 04:10:40 2017] [ 5775] 0 5775 9454 269 22 3 193 0 rpc.mountd
[Thu Jul 6 04:10:40 2017] [ 5776] 0 5776 33564 612 32 3 303 0 minidlnad
[Thu Jul 6 04:10:40 2017] [ 5786] 0 5786 1021 135 7 3 20 0 apache_log
[Thu Jul 6 04:10:40 2017] [ 5787] 0 5787 1021 133 7 3 20 0 apache_log
[Thu Jul 6 04:10:40 2017] [ 5788] 0 5788 34593 0 66 3 945 0 apache2
[Thu Jul 6 04:10:40 2017] [ 5789] 98 5789 34601 231 69 3 950 0 apache2
[Thu Jul 6 04:10:40 2017] [ 5790] 98 5790 34601 231 69 3 950 0 apache2
[Thu Jul 6 04:10:40 2017] [ 5791] 98 5791 34601 231 69 3 950 0 apache2
[Thu Jul 6 04:10:40 2017] [ 5792] 98 5792 34645 367 69 3 992 0 apache2
[Thu Jul 6 04:10:40 2017] [ 5793] 98 5793 34601 231 69 3 950 0 apache2
[Thu Jul 6 04:10:40 2017] [ 6013] 99 6013 88777 1230 167 3 890 0 smbd
[Thu Jul 6 04:10:40 2017] [18601] 0 18601 6768 806 18 3 130 -1000 bash
[Thu Jul 6 04:10:40 2017] [18784] 0 18784 10213 847 24 3 113 -1000 msmtp
[Thu Jul 6 04:10:40 2017] Out of memory: Kill process 6013 (smbd) score 4 or sacrifice child
[Thu Jul 6 04:10:40 2017] Killed process 6013 (smbd) total-vm:355108kB, anon-rss:84kB, file-rss:4836kB
[Thu Jul 6 06:15:08 2017] usb 2-2: reset high-speed USB device number 3 using ehci-pci
[Thu Jul 6 06:15:08 2017] sd 7:0:0:0: [sdf] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK
[Thu Jul 6 06:15:08 2017] sd 7:0:0:0: [sdf] tag#0 CDB: Read(10) 28 00 00 00 00 3f 00 00 01 00
[Thu Jul 6 06:15:08 2017] blk_update_request: I/O error, dev sdf, sector 504
[Thu Jul 6 06:15:20 2017] nr_pdflush_threads exported in /proc is scheduled for removal
btrfs.log
Label: '5e26ecb8:root' uuid: 6a44d55d-1d4f-4ed6-98c8-4dc10fcb90e2
Total devices 1 FS bytes used 536.44MiB
devid 1 size 4.00GiB used 1.24GiB path /dev/md0
Label: '5e26ecb8:DATA' uuid: f52711ff-56a4-422e-829b-3ba0f774dd83
Total devices 1 FS bytes used 3.11TiB
devid 1 size 8.17TiB used 3.12TiB path /dev/mapper/DATA-0
=== filesystem /DATA ===
Data, single: total=3.11TiB, used=3.10TiB
System, DUP: total=32.00MiB, used=384.00KiB
Metadata, DUP: total=6.50GiB, used=4.85GiB
GlobalReserve, single: total=512.00MiB, used=0.00B
=== subvolume /DATA ===
ID 257 gen 30 top level 5 path .purge
ID 258 gen 7103 top level 5 path ._share
ID 259 gen 7847 top level 5 path .apps
ID 260 gen 13 top level 5 path home
ID 261 gen 13 top level 5 path .vault
ID 264 gen 5664 top level 5 path .timemachine
ID 265 gen 7102 top level 5 path Videos
ID 266 gen 7103 top level 265 path Videos/.snapshots
ID 970 gen 809 top level 266 path Videos/.snapshots/1/snapshot
ID 2236 gen 7096 top level 5 path Software
ID 2237 gen 7097 top level 2236 path Software/.snapshots
ID 2356 gen 7093 top level 5 path prepping
ID 2357 gen 7094 top level 2356 path prepping/.snapshots
ID 2358 gen 7087 top level 5 path Backup
ID 2359 gen 7088 top level 2358 path Backup/.snapshots
ID 2466 gen 2485 top level 2359 path Backup/.snapshots/1/snapshot
ID 2467 gen 2487 top level 2357 path prepping/.snapshots/1/snapshot
ID 2468 gen 2489 top level 2237 path Software/.snapshots/1/snapshot
ID 2469 gen 2491 top level 266 path Videos/.snapshots/2/snapshot
ID 2470 gen 7090 top level 5 path Music
ID 2471 gen 7091 top level 2470 path Music/.snapshots
ID 2817 gen 2992 top level 2359 path Backup/.snapshots/2/snapshot
ID 2818 gen 2995 top level 2471 path Music/.snapshots/1/snapshot
ID 2819 gen 2998 top level 2357 path prepping/.snapshots/2/snapshot
ID 2820 gen 3001 top level 2237 path Software/.snapshots/2/snapshot
ID 2821 gen 3004 top level 266 path Videos/.snapshots/3/snapshot
ID 3368 gen 5247 top level 2359 path Backup/.snapshots/3/snapshot
ID 3369 gen 5250 top level 2471 path Music/.snapshots/2/snapshot
ID 3370 gen 5253 top level 2357 path prepping/.snapshots/3/snapshot
ID 3371 gen 5256 top level 2237 path Software/.snapshots/3/snapshot
ID 3372 gen 5259 top level 266 path Videos/.snapshots/4/snapshot
ID 3373 gen 7848 top level 5 path Triimaging
ID 3374 gen 7100 top level 3373 path Triimaging/.snapshots
ID 3472 gen 7087 top level 2359 path Backup/.snapshots/4/snapshot
ID 3473 gen 7090 top level 2471 path Music/.snapshots/3/snapshot
ID 3474 gen 7093 top level 2357 path prepping/.snapshots/4/snapshot
ID 3475 gen 7096 top level 2237 path Software/.snapshots/4/snapshot
ID 3476 gen 7099 top level 3374 path Triimaging/.snapshots/1/snapshot
ID 3477 gen 7102 top level 266 path Videos/.snapshots/5/snapshot
=== btrfs dump-super /dev/md0
superblock: bytenr=65536, device=/dev/md0
csum_type 0 (crc32c)
csum_size 4
csum 0x504bfd7c [match]
bytenr 65536
flags 0x1
( WRITTEN )
magic _BHRfS_M [match]
fsid 6a44d55d-1d4f-4ed6-98c8-4dc10fcb90e2
label 5e26ecb8:root
generation 5732
root 175390720
sys_array_size 129
chunk_root_generation 77
root_level 0
chunk_root 20987904
chunk_root_level 0
log_root 0
log_root_transid 0
log_root_level 0
total_bytes 4290772992
bytes_used 562499584
sectorsize 4096
nodesize 16384
leafsize 16384
stripesize 4096
root_dir 6
num_devices 1
compat_flags 0x0
compat_ro_flags 0x0
incompat_flags 0x161
( MIXED_BACKREF |
BIG_METADATA |
EXTENDED_IREF |
SKINNY_METADATA )
cache_generation 18446744073709551615
uuid_tree_generation 5732
dev_item.uuid 496486b4-fef3-40ab-bf7b-25ca3e7a449b
dev_item.fsid 6a44d55d-1d4f-4ed6-98c8-4dc10fcb90e2 [match]
dev_item.type 0
dev_item.total_bytes 4290772992
dev_item.bytes_used 1326579712
dev_item.io_align 4096
dev_item.io_width 4096
dev_item.sector_size 4096
dev_item.devid 1
dev_item.dev_group 0
dev_item.seek_speed 0
dev_item.bandwidth 0
dev_item.generation 0
sys_chunk_array[2048]:
item 0 key (FIRST_CHUNK_TREE CHUNK_ITEM 20971520)
length 8388608 owner 2 stripe_len 65536 type SYSTEM|DUP
io_align 65536 io_width 65536 sector_size 4096
num_stripes 2 sub_stripes 0
stripe 0 devid 1 offset 20971520
dev_uuid 496486b4-fef3-40ab-bf7b-25ca3e7a449b
stripe 1 devid 1 offset 29360128
backup_roots[4]:
backup 0:
backup_tree_root: 174800896 gen: 5730 level: 0
backup_chunk_root: 20987904 gen: 77 level: 0
backup_extent_root: 174768128 gen: 5730 level: 1
backup_fs_root: 174702592 gen: 5730 level: 2
backup_dev_root: 31178752 gen: 4980 level: 0
backup_csum_root: 168624128 gen: 5693 level: 1
backup_total_bytes: 4290772992
backup_bytes_used: 562483200
backup_num_devices: 1
backup 1:
backup_tree_root: 175226880 gen: 5731 level: 0
backup_extent_root: 175063040 gen: 5731 level: 1
backup_fs_root: 174833664 gen: 5731 level: 2
backup_csum_root: 174948352 gen: 5731 level: 1
backup_bytes_used: 562499584
backup 2:
backup_tree_root: 175390720 gen: 5732 level: 0
backup_extent_root: 175357952 gen: 5732 level: 1
backup_fs_root: 175243264 gen: 5732 level: 2
backup 3:
backup_tree_root: 174669824 gen: 5729 level: 0
backup_extent_root: 174637056 gen: 5729 level: 1
backup_fs_root: 174538752 gen: 5729 level: 2
- dsm1212Jul 06, 2017Apprentice
You had an io error on sdf. A USB drive? I had a bad USB disk and it caused hangs like this after errors (an earlier version of os6, but I don't think it matters this is a linux driver bug). I never reported it because frankly I tested the disk under windows and found many errors so I replaced it. You might be able to "correct" it with a disk scan utility or check your usb connections...
- BofcJul 07, 2017Aspirant
i saw that too, but as it is an external 3TB drive connected to the back USB ports and not being accessed by the copy job i am doing, i did not give it much thought.
i think i know what is going on, i looked back through the copy jobs and when i started them and when they failed. it appears to be that the CPU/memory resources are not enough to handle the copy job with the added overhead of encrypting, bit-rot (copy on write, and compression WITH a scheduled task like balancing, disk test, defragging, etc. i arrived at this conclusion by noting the scheduled event would start and shortly after the logging would stop and new entries would be in the log were i booted the system up again.
yesterday i stopped all scheduled events (this morning a defrag was set for 2:00am) and have been coping data since yesterday mornings reboot.
i will have to wait to see if this copy job of several million fiiles and between 2-3TB finishes (scheduled disk jobs disabled). so far it has copied 4 times more than any previous copy attempt that was interupted with the system hangs (scheduled disk jobs enabled).
- BofcJul 18, 2017Aspirant
so the problem continues, when i stopped the disk scrubs, defrags, and balancing, i was able to finish the coping of files to the ReadyNAS. so i started the defrag and it did start, but the NAS has locked up serval times and displayed "out of memory - 9f2" on the front display before completing, now in a short amount of time (30-45min) the readynas just lockes up when i attempt a defrag, no message, no event log notices, nothing.
so i have to assume it is locking up due to out of memory still and the only way to access it again is to reboot the NAS. i know this is an unsupported setup. but figured i would atleast give some feedback and wait for the next version to be released to see if it helps any.
the space used is ~4.3TB out of 8.7TB and has roughly 4 million files. bit-rot is enabled on the shares and compression is enabled on a couple of them. the volume is encrypted.
anyone else experencing this?
thank you.
