Bofc
Jul 05, 2017Aspirant
intermittent lockups readynas pro 4 on firmware 6.7.5
hello, i know there is no support with the lagacy readynas pro 4 running firmware 6+, but figured i would let you know of an issue i have been having. upgraded to firmware 6.7.5 from 4+ and have been...
Bofc
Jul 25, 2017Aspirant
Well the new 6.8.0 beta firmware did not change anything. but was worth a try. the defrag job ran for 13 hours and 35 minites according to the SSH session i had open running "top". i have disable everything i could find to bring the memory footprint down that services were using. so now i am looking at what it will take to modify the settings in the OS/Application to allow defrag to run with reduced resources needs.
does someone know what applicaiton is being used to run the defrag? is it BTRFS? and any commands that i can use to attempt a manual running of the defrag application?
thank you.
jak0lantash
Jul 25, 2017Mentor
Have you tried disabling the quota accounting from the volume settings?
