Bofc
Jul 05, 2017Aspirant
intermittent lockups readynas pro 4 on firmware 6.7.5
hello, i know there is no support with the lagacy readynas pro 4 running firmware 6+, but figured i would let you know of an issue i have been having. upgraded to firmware 6.7.5 from 4+ and have been...
Bofc
Jul 25, 2017Aspirant
as far as i can tell i do not have quotas set up anywhere, i have also disabled snapshots. bit-rot protection, compression, and encryption is on.
is there a quota service to check or simply looking in the GUI to show that quota in not enabled all that is needed to verify it is off?
jak0lantash
Jul 25, 2017Mentor
Having no quotas set on shares doesn't mean having BTRFS quota support disabled at the volume level. Check under the settings of the volume, there is a checkbox for it.
