chhumper
Jan 28, 2015Aspirant
ip assignment issues
hi. apologies if this isn't posted in the right place. i'm struggling to connect with my readynas ultra 4 and i cannot figure out the following: i am using an almond+ router that assigns ip address...
chhumper
thanks. if it was a NIC issue, would it affect both of the ethernet ports? as far as i can tell, when the cable is plugged into either, i get the same 192.168.168...
