Anonymous
Sep 11, 2013IP problems
I've had some problems with my ReadyNAS Ultra 4 recently, i thought it was dead because it wouldn't start anymore but after unplugging it for a few hours it started working back. The only problem n...
Anonymous
Sep 12, 2013
fastfwd wrote:
anarchoi wrote:
fastfwd wrote: If you have recently moved your Ultra 4's Ethernet cable from one port to the other, move it back.
yep, i think i did switch the ethernet cables recently. I just tried switching them back, but the IP is still 192.168.2.100 after reboot :(
"Cables", plural? I was suggesting that just one end of one cable was moved -- from one of the sockets on the back of your Ultra 4 to the other socket on the back of your Ultra 4. Each socket has its own MAC; your router probably can't be configured to assign .10 to both MACs, so if it sees the wrong one it will just pick an IP address out of its DHCP pool, which probably starts at .100.
Oh i just got what you mean, i thought you was talking about switching the cables between my Ultra 4 and my Ultra 4 Plus
I did change the ethernet port of my Ultra 4 and it actually fixed the problem.
Thanks !
