miahz
Mar 17, 2011Aspirant
Irregular/Slow Read Speed from NV+ over Gigabit
I'm struggling to understand my problem, but i'll do my best to explain below. Basically: i get wildly different results when copying files/folders in OS X Finder from my NV+. Ok, getting the sp...
mdgm-ntgr
Dec 12, 2011NETGEAR Employee Retired
I agree.
I have 14 drives with the CC1H firmware and they're fine.
If still on 4.1.7 I would stay on that for now. There are some performance issues with 4.1.8. 4.1.9 (currently in beta: http://www.readynas.com/forum/viewtopic.php?f=17&t=59222) addresses this issue. I would update to 4.1.9 once it goes production and then update to Mac OS X 10.7 Lion (note Lion is incompatible with PowerPC apps so check if you have any of these before updating to Lion) if you wish. If you are happy with Snow Leopard I would stick with it. Lion isn't as reliable as Snow Leopard in my opinion and unless you want to use iCloud or the new versions feature it doesn't really offer much over Snow Leopard.
