greg_t
May 16, 2013Aspirant
Is backup of a subset of shares possible?
Hi, Is it possible to backup a specified set of shares to a USB drive using Frontview? We use our ReadyNAS for file sharing as well as system-wide backups. I would like to back up all but the b...
May 16, 2013Guru - Experienced User
You can't create a backup job for a group of shares.
But you can create a separate backup job for each share in the group, and put them on the same schedule.
