greg_t
May 16, 2013Aspirant
Is backup of a subset of shares possible?
Hi, Is it possible to backup a specified set of shares to a USB drive using Frontview? We use our ReadyNAS for file sharing as well as system-wide backups. I would like to back up all but the b...
vandermerwe
May 27, 2013Master
No.
You would either need to set separate backups for each folder, or use rsync and exclude folders you don't want to backup.
The other strategy would be to use other backup software on your PC to backup to a USB drive attached to the PC or. Readynas. A bit cumbersome as you need your PC on and it's slow.
