greg_t
May 16, 2013Aspirant
Is backup of a subset of shares possible?
Hi, Is it possible to backup a specified set of shares to a USB drive using Frontview? We use our ReadyNAS for file sharing as well as system-wide backups. I would like to back up all but the b...
vandermerwe
May 27, 2013Master
Yes, you can specify whatever path you wish.
For the source you should be able to click browse to set the path.
The destination path needs to be entered manually.
If you click on help in the backup section of Frontview it has some sample paths for different protocols which will help you to enter these correctly.
Why not just backup the whole share? Do you not have enough space?
